Change locations inside seam
Hi everyone,
im using PD+Ps 10.1 standalone.
At the moment  I´m trying to create different  arc seams, but there is a small problem I´m unable to fix - how can I change the sequence of the locations inside a seam? Is there any possibility to switch the start and stop location? Do I have to change the orientation of the orginal polyline?
Re: Change locations inside seam
I'm not familiar with 10.1 version, but try to find Reverse Operation command. In version 11 and higher this works correctly.
Dave
Tha´ts it - I´ve tried for 20 minutes to pick and place the locations and was wondering why this doesn´t work. Smiley Tongue
Thank you, Dave007!
