Changing part prototype
Hi guys,
is it possible to change a part prototype in PD like the function "change resource prototype"?
I want to "update" some parts in my library to an newer version.
Thanks!
Re: Changing part prototype
Usually what I do is to replace the jt file inside the cojt folder pointed for the prototype file that I want to replace (you can check the folder by entering the prototype properties, at Physical Tab), or even change the path of 3D file to a new cojt folder.
Those two methods are enough for my needs of updating parts.
