Columns not available in Path Editor
Hi guys,
Do you know why some columns, from General group, are not available in Path Editor?
I'm using Process Simulate 14.1.2.
Thanks in advance Smiley Happy.
3 REPLIES 3
Re: Columns not available in Path Editor
Hi . You might accidentally close some windows in operation then you can't see them...
Easy to revovery. Select' Standard view' in the 'model' tab. then everything backs to inital ones.
Siemens Legend Siemens Legend
Siemens Legend
Well if you click "Z" again and it still does not enable the "add" button (right poiting arrow) than it simply looks like a weird bug.
Did closing and reopening solve it...?
It does not look like any bug I've seen before.
Kind regards,
Gal Snir
I know it's a weird thing Smiley Very Happy.
The idea is that this problem I had with Process Simulate 14.1.2.
Right now I'm using 14.1 version because of project requirements.
I'll keep in mind what you said.
Thanks Smiley Happy
