ComauPdl controller version 3.15
Hi Gilles!
installed the version 3.15, and tested the SELECT command, the parentheses error over.
But the result in the variable is zero, the variable does not carry the RETURN value 2.
How to fix?
Re: ComauPdl controller version 3.15
val_int versus val_init...
Excuse me, was the elation. Smiley Very Happy
 Ok, works!
