Compounding part appearances into assembly
Is it possible to compound multiple part appearances into one appearance?
I have read that it has been impossible in earlier versions of Process Simulate --> But you could collapse your appearances Under a "compund part" like the attached file shows (just an example).
The next question is how to make them (multiple appearances) to collapse under the Compound Part?
A help would be very appreciated!
Best regards
SaMe
Re: Compounding part appearances into assembly
You can add a button with Options -> customize, add the Substitute Instances button. You can create a master instance with multiple other instances in it. I havent tried it myself but I think this could work for you.
Hello Pim and thank you for the reply,
Neither do I need it at the moment but I was curious about it because I once struggled with this. And I will need this in a few weeks.
Best regards
SaMe
