Control Instructions
Hello all,
 I would like to know how to use control instructions such as If else, for, while, do-while instructions in robot expert?? Is it possible to those logics in robot expert?
 Thanks in advance
Suganth
Re: Control Instructions
Pls find the controller documentation in eMPower\Robotics\Olp\your-controller\doc
You should find the complete supported instruction-set there.
