Convert and Insert CAD files
Since i've installed the hotfix :'CADTranslators31hotfix01-x64.msi', I can't use the function 'Convert and Insert CAD files' anymore.
Before I installed that hotfix, I could use this function without any problems.
Does anyone has a solution for this?
Thanks in advance!
R_Cloesen
Re: Convert and Insert CAD files
Siemens Genius Siemens Genius
Siemens Genius
What do you mean by "can't use"? is there any message? license issue? does the dialog open at all? which format do you try to convert?
Gil.
No, nothing happens, no error message, nothing..
Siemens Genius
We're not aware of issues with any HF that corrupts the cad conversion.
You may try to reinstall or even use the newer version of it - 4.0. This week, a newer version, 4.1 will be released, so maybe you should wait for the newest version of CAD Translators.
Gil.
I reinstalled PS and now everything works fine again..
Thanks for the help!
