Converting DGN Microstation in JT format
Hi
I need a solid way to convert Microstation dgn into a jt file for process simulation. At the moment these are the current method
1. Convert in microstation to jt file. The first step is to create 2D dgn and then export JT.
2. Create 2D dxf from microstation. Import into fides and then export JT.
3. Create 2D dxf from microstation. Convert to .co with robcad CAD translator dxfin. Then use upgrade to cojt.
All of the above do not always work and are slow. Is there a better method that always works to create these jt files for process simulation.
Thanks you.
Re: Converting DGN Microstation in JT format
maybe use 3rd party translation software like Datakit or others to do batch tralanslation. it might support microstation files to jt conversion.
there is a JT-export for Microstation available.
But I don't know if it's an extra license.
http://communities.bentley.com/products/microstation/w/microstation__wiki/how-to-export-a-model-into...
