Create IPA nodes in Process Simulate
Hi All,
Is it possible to create the Assembly tree/ IPA nodes from Process Simulate instead of Process Designer?
I would like to do it from Process Simulate because I do not have the license for process Designer
Best regards,
Axel
Re: Create IPA nodes in Process Simulate
Siemens Genius Siemens Genius
Siemens Genius
Unfortunately there is not a way to run Generate IPA in Process Simulate.  2 Things are required from what I know.  1) Pert Viewer to create the flow from station to station and 2) Generate IPA function.  These are Process Designer specific functions.
You will have to manually build the IPA in a product structure.
