Custom XML - Name of location
Hello Forum,
this is my first post and I hope to write all the necessary information.
I have a problem and didn't find a solution via the search function...Smiley Indifferent
I started programming the XML files for Path template Configuration.
My goal is to get a function which displays the name of the current Location in the download layer (LocName).
The downloaded Code should look like:
  MoveL LocName,v50,fine,tGripper\WObj:=wobj1; !actual robot position stActPos:="LocName"; RETURN;
ENDPROC ...
and here is the code I tried:
    <Command Name="ActPos">
      <RoboticParamRef>
		    <ParamDynamic>'LocName'</ParamDynamic>
      </RoboticParamRef>
      <Layers>
        <UILayer>
			    <Line>
				    <Item Type="const">actual Position </Item>
					<Item Type="parameter">LocName</Item>
			    </Line>
        </UILayer>
        <SimulationLayer>
        </SimulationLayer>
        <DownloadLayer>
				<Line>
				    <Item Type="const">!actual robot position </Item>
				</Line>
				<Line>
				    <Item Type="const">stActPos:="</Item>
					<Item Type="const"><![CDATA[";]]></Item>
			    </Line>
				<Line>
					<Item Type="const"><![CDATA[RETURN;]]></Item>
			    </Line>
        </DownloadLayer>
      </Layers>
    </Command>
The Customized Command XML Checker shows the following error:
Error:Reference to robotic parameter:"LocName" could not be found in command RoboticParamRef list.
Where can I find the RoboticParamRef list?
I am using RobotExpert v13.0.1 with ABB-Rapid
Thanks for any help!
Re: Custom XML - Name of location
I guess you meant:
<Item Type="dynamicParameter">Loc Name</Item>
And you do not need this:
Wow, that was fast - and worked perfectly!
Thank you very much!Smiley Happy
I just need to dind the "Solved" checkbox Smiley Wink
