Deactivating and replacing with another program in TIA
Hello to all!
How can I deactivate a program in TIA portal and create another one in stead? How can I make the links and which are the commands to do that?
Thank you in advance!
Have a nice day!
Vasi
Re: Deactivating and replacing with another program in TIA
Siemens Legend Siemens Legend
Siemens Legend
Hi vasi
If you are asking a question related to TIA portal directly, than you need to do so in the TIA portal forum (that's Siemens Automation and not Siemens PL). You can find the right forum by a simple Google Search.
If you are asking a question regarding the use of Process Simulate with TIA portal for Virtual Comisionning, you will need to further clarify your wishes and what you are doing.
Kind regards,
Gal Snir
