# Display / # Blank function
Is there a chance to blank or display links or individual entry's of gripper via custom xml's?
in OLP Commands i can select the individual entry.
but i search a solution for custom xml's.
Kind regards,
Benjamin Voelzke
Re: # Display / # Blank function
Yes, you can use names "à la Robcad, ex: grip1.bo1 to display/blank entity bo1 from grip1. The "." should follow the object entity hierarchy (ex: grip1.group1.bo1 to refer to bo1 being under node group1, itself under gripper component).
