End Modeling in Process Simulate
Hello Community,
I have a problem while i am doing end modeling in Process simulate after defining the links and joints for a kinematic device i am getting an error like as shown in the picture below...so please let me know why that error is coming...?large (1).jpglarge.jpg
Re: End Modeling in Process Simulate
Please check that there are no whitespaces in the joints name, especially at the end. E.g. "j1 ".
Check with your cursor. The name should consist of numbers and letters.
Best regards
When the kinematic editor closes without error message you are fine regarding the kinematic. I'm not aware of any naming conventions for any object entities.
But if after modelling the component cannot be stored, it's usually a wrong filename. Avoid whitespace and 'minus'. Use underscore instead.
On my machine on rare occasions it might happen, that a component is blocked from saving by Windows. You might use the freeware 'unlocker' to check what process is holding it.
