cancel
Entitie Information
In Robcad it was possible to get entitie informations for every type of komponents.
Like distance to orign, to workframe, name of orign component.
Is there a way to get this informations in RobotExpert?
Can i rename components after modeling?
Re: Entitie Information
Siemens Legend Siemens Legend
Siemens Legend
Hi Robolab.
I'm not a Robcad user, so I am not familar with what you are refering to, but there's no "stats" panel for Entities in Process Simulate. To get the distance from the Origin or Working Frame you can use Measurements or Dimensions directly on the Entity.
You can rename Components after End Modeling. Keep in mind that this name is NOT SAVED in the COJT, but rather in the RE cell itself as this is the specific Instance's name and not the name of the Prototype.
Kind regards,
Gal Snir
