Error while importing JT file in Process Simulate
Getting an error while importing a JT file in Process simulate.
The error shows as
"Failed to import JT File(a problem occured when running TxJt2co.exe).
C:sysroot\JT_co\*****.jt
The executable TxJt2co.exe is not found
The convertion failed.
Presently the modules we have are
TN70005NU
TN70020NU
TN70080NU
TN55065NU
Raju
Re: Error while importing JT file in Process Simulate
Have you installed the CAD translators?
it is usualy on DVD2 on the Tecnomatix installation kit.
