Failed to load data from eMServer
I am using TX10.1 in a multiuser environment.
When I try to load a study from a client machine, i get the error:
What's the cause of this? Is it related to access rights?
Thanks.
Re: Failed to load data from eMServer
Dear Endreszucs,
There may be sevaral reasons, i can give you some reasons which i have gone through.
1. Inside SysRoot under your station directory and inside robot cojt folder .JT file may be corrupted. to solve this please replace the .JT file of the same robot model.
2. You maight have left Fixture or Tool in the modeling mode and assigned signals, fixture operations associated with process.
3. System unable to oot your Station Process.
Kind Regards,
Sudhakar K
