Fanuc RCS Error -50
Hello People,
When initializing the RCS with a Named Robot that I created using the Fanuc-Software, I keep getting the error message "The RCS could not be initialized: Other error (-50)". Does any of you know what exactly this error means and how to fix proplems like this in general?
I use Controller Fanuc-Rj, version V8.30, RCS version normal
Thanks a lot for your help.
Re: Fanuc RCS Error -50
Hi
I am getting the same error when trying to initialize M900ib400L robot on a RTU slide with Servo gun using RCS v8.30D.  I can get other models of robots to work with 2 axis but not this this model.  I opened an IR with Siemens and waiting to see if Siemens gets the same error message.
