Fanuc RCS problem
Hello together
I have a problem, im trying to link the RCS module from fanuc to PS standalone, I already have followed the steps to install it, (Install Fanuc RCS setup, download an put the j3_rcs_tune_debug.exe, and j3_rcs_tune.exe, edith the rrs.xlm) When I open PS the options of RCS are active, the problem is I can not choose a "manipulatortype", I dont know what I doing wrong? maybe could be configuration of fanuc rcs client, because I dont have the files that appears in the manual instalation (frvcr_client.conf.example, rcsserver.reg, ... )
Has somebody knows why I cant choose a manipulatortype, or where can I found the files that are missing??
Re: Fanuc RCS problem
You need first to install the Fanuc RCS client for Robcad (that contains the missing .dll and .reg) [https://download.industrysoftware.automation.siemens.com/download-n.php/tecnomatix/product_updates/R...] and inside put the Fanuc RCS client Tune AddOn for Process Simulate.
Excellent, now the rcs works,
Thank you!
hello GillesVelay,
how to download fanuc RCS client Tune AddOn for Process Simulate?
thanks.
paul
Just search in the gtac this file: rcsfr13.v6_1_2.TuneAddOn.21_04_2017.client.pc
hello Elias Paredes ,
Thanks very much.
by the way, can you give me a manual about how to use fanuc rcs in ps step by step?
thanks in advance.
Paul
Hello, I sent you a message.
How can I get this RCS Files for Fanuc R200ic_210f?
Hello Elias Paredes ,
Could you please send me the manual about how to use fanuc rcs in ps step by step?
And if possible, could you please send me if there is any document for the Fanuc RCS configuration process with Process Simulate also.!
Thanks in Advance,
Ram
