Do you mean
Reply
Solved! Go to solution
Fanuc-RJ-Vw
we're using PS10.1 now and working with Fanuc Robot for VW. We have all the necessary licenses, for Fanuc,PS e.t.c., but the problem is that for Fanuc VW Fanuc-RJ-VW tool is needed, not simple Fanuc-RJ. I searched all around the downloads section and found only Fanuc-RJ under   >  product updates - planning applications - robot controllers - v10.1 - fanuc . Looks like for downloading VW version I need the exact name of file (smthng like Tecnomatix_11.1_FANUC_RJ_VW_64BIT_vXXX.XXx) but I don't know the name! So the question is- am I right or should I look somewhere else? How to get this file? Our patners are only able to give us a version for PS11, and of course it does't work.
Solution
Solution
Accepted by topic author sterxx
‎03-15-2016 04:36 AM
Re: Fanuc-RJ-Vw
please get in contact with GTAC.
You can call them or you can create a web IR.
They will give you the link and the exact filename for the download.
Patrick
Re: Fanuc-RJ-Vw
Thank you! In fact we did this before I posted this question but their answering speed could be better Smiley Happy
