Fanuc download template settings
where is stored the settings for the Fanuc download template selection? I need to set it from an external app (not using the standard dialog - Robot Setup - Program Template Selection).
What is for the C:\Program Files\Tecnomatix_12\eMPower\Robotics\OLP\Fanuc-Rj\DownloadTemplatesConfiguration folder?
This is a RE 11.1TR3 project, but I think the question is general for PS/RE across the versions.
Dave
11 REPLIES 11
Re: Fanuc download template settings
I'm afraid it is stored in the .cell file.
Man Frustrated
Is there any way how to set it from outside?
D.
It is stored as robotic parameter on the robot instance. Please use free tool "Robotic Robotic Parameter Viewer" to see the exact parameter name and contents.
C:\Program Files\Tecnomatix_12\eMPower\Robotics\OLP\Fanuc-Rj\DownloadTemplatesConfiguration folder is used for the XML based program template (versus the regular ASCII templates). Please see the XML documentation under Robotics\Olp for more information.
Thak you very much.
I would like if is posible to use Fanuc-Rj default template (.xml) to modify it and create a new custom .xml, with others olp commands. In this case, where can I find it?
Thanks very much.
There is no default template for OlpConfiguration XML Customization.
So, where can I find the files that generates this menus?
They are inside the controller dll (hard coded if you like)
Oops...  Do you know where can I find any custom xml? I need a template to customize a xml from the beginning.
