Frame name
Hi, is it possible to rename frames?
Re: Frame name
Ha! Got it. ClickOnName - Wait - ClickOnName - Type...
Re: Frame name
Siemens Genius Siemens Genius
Siemens Genius
or select the frame, then use the F2 keyboard key' like the Windows standard rename method.
Re: Frame name
Hey!
Is there a way to group some frames to one folder..
ex;
Frames
-Folder A
    FrameAX
    FrameAY
-Folder B
    FrameBX
   FrameBY
Re: Frame name
hi,
yes can group frames.
open logical collection tree (see viewer)
right click -> create new group
in the new window you can select frames.
the selected frames is include the group.
in this way can can export the group to excel.
Kind regards,
Benjamin Voelzke
