How to create a robot program with multiple weld operations?
Good morning everyone,
I work with PS / PD 10.1. At the moment I try to create a .mod-file for an ABB IRC5-Robot with multiple Compound Operations.  I´ve tried this way seen below, but this doesn`t work.  Is this the right way or is there a smarter solution?
Greeting,
thebang2
Re: How to create a robot program with multiple weld operations?
do you see the created program in the Robotic Program Inventory (Robotics - Robot program - Robotic Program Inventory)?
I'm working in 11.1 version and the "Create robotic program for compound operation" function works fine. Could you be more specific and describe, what exactly the PS does?
Dave
Yeah, thats'`s it. -.-
I´ve expected a popup window like the in "download to robot" or something.
Thanks for your help!
You are welcomeSmiley Happy
Dave
