How to export a good quality 3D file from Process Simulate
Hello!
I'm having problems to get 3D files out from Process Simulate.
As a Robcad user, I'm used to get WRL (or VRML) files from it, which has a very good quality and normally any software can open it.
I tried to use the "Export JT" command, but the generated files are not good as the Robcad ones.
See attached image to have an idea of what is happening.
Can anyone help me how to export a good quality 3D file from Process Simulate?
Thanks!
Re: How to export a good quality 3D file from Process Simulate
hi,
from Process Simulate you can only export JT as 3D file.
In PSv11.1 or higher, it is possible to export JT with "Exact Geometrie".
Patrick
