How to export data of Joint Properties from Kinematics Editor (about ps13.0)
Hi All:
    For some reasons, I want to export the data of Joint Properties from Kinematics Editor (about ps13.0).
Firstly,Click "Set Modeling Scope"Set Modeling Scope.png, Then Click "Kinematics Editor" Kinematics Editor.png
The UI shows as below:
Is there any API for user to get the Joint Properties?
Re: How to export data of Joint Properties from Kinematics Editor (about ps13.0)
Siemens Legend Siemens Legend
Siemens Legend
Yes there is an API.
Check this: ITxKinematicsModellable.Joints
It is implemented by all sorts of TxObects, e.g., TxDevice, TxRobot.
This property returns a TxObjectlist containing objects of type TxJoint.
TxJoint exposes all sort of joint properties.
Example:
List<double> GetAllJointsMaxSpeed(TxRobot robot)
       List<double> maxSpeeds = new List<double>();
       foreach(TxJoint joint in robot.Joints)
            maxSpeeds.Add(joint.MaxSpeed);
       return maxSpeeds;
Kind regards,
Zachi
@Zachi_Mann wrote:
Example:
       return maxSpeeds;
Kind regards,
Zachi
Hi Zachi:
     Thank you for your reply.
But in my project code, I can not find TxRobot object.
My project implement from CApDefaultLibRobot abstract class .
    public abstract class CApDefaultLibRobot : COlpUtilRobot
        public CApDefaultLibRobot(COlpUtilRobot robot);
        public StringCollection AvailableWorkToolNames { get; }
        public StringCollection AvailableZoneNames { get; }
        public override TxFrame RrsWorldFrame { get; }
        protected override string ComputeManualRrsConfigString(COlpUtilLocation loc, TxRobotConfigurationData config, TxPoseData jointSolution);
        public TxFrame GetToolFrameFromName(string toolFrameName);
        protected override void Init();
        public override void WrapLocation(ref COlpUtilLocation loc);
And in the COlpUtilRobot class I also can not find TxRobot object.
So, How can I get the TxRobot object?
Siemens Legend
Might be try:
CApDefaultLibRobot defLibRobot = ....;
TxRobot robot = defLibRobot.TxObject as TxRobot;
