How to export selective JT data from Process Simulate?
An interference situation of robot with fixture at particular weldspot is to be shown to designer. The designer needs to have in formats like JT or CGR
How can the robot situation like these be shown to a designer?
In Delmia V5, its simple
1. Reach the robot to the weldspot
2. Select the required geometry to be exported
3. In context menu select "Export to CGR "
Any hopes ?
Thanks in advance
Re: How to export selective JT data from Process Simulate?
Siemens Genius Siemens Genius
Siemens Genius
You can export the scene (all displayed components) to JT and then load to other CAD application like NX. This will load the robot/gun with the same pose (joints values) as in Proess Simulate.
See 2 images I attached:
1 - export from Process Simulate.
2 - load into NX.
Gil.
