How to generate a "ComboBox" from the names of the robots signals
I created a "ComboBox" in "OlpConfiguration", but every time there is an update on some robot signal, I have to change the name in the "ComboBox" as well.
Is there a way to map the names of robotic signals in the "Robots Signals" table and insert into the "OlpConfiguration" XML?
If I could detect these signs, it would be better.
