How to get the softclass type .NET
Hi How do I go about getting the type of the planning object through .NET see attached picture of what I am looking for. This is what I have ITxPlanningObject PlanningObject = TxApplication.ActiveDocument.Selection.GetPlanningItems.Item(0); string Object_type = PlanningObject.GetField("type"); But this just returns a empty string. Thanks
6 REPLIES 6
Betreff: How to get the softclass type .NET
I think it doesn't work in disconnected.
See a similar problem in Get prototype name
Hi
Thanks but this is connected mode. I have np problem getting the prototype path. I need the type as displayed in my attached picture.
Thanks any help will be greatly appreciated
Re: How to get the softclass type .NET
Did you have a look into the PlanningType property of your ITxPlanningObject? It should return the string you are looking for.
Snippet
String planningType = planningObject.PlanningType;
Edit:
Forgot to mention it, I guess you want to go a little further than just retrieving a string. But once you got the string, you can use the TxPlanningTypeMetaData class to get some more information:
Snippet
TxEmsGlobalServicesProvider servicesProvider = new TxEmsGlobalServicesProvider();
TxPlanningTypeMetaData metaData = servicesProvider.GetTypeMetaData(planningType);
With that, you can find out which fields you have access to etc. But please don't ask me why they implemented it this way ;-)
Did you manage to solve the problem?
I've got a similar problem.
When I try to get which type of object I have using:
I just get PMToolInstance
Hi
Please below I got the prototype from the instance with
Prototype = Instance.PlanningRepresentation.GetField("masterObj")
and then
Prototype.PlanningType
Thank you for your answer.
It doesn't solve my problem completely, but it takes me a bit closer to my goal.
