Re: How to import .JT to Process Simulate?
HEELO
if you help me with convert how can i convert it. if you have som link of that converter please post it.
thank you
The CAD Translators are on your Installation DVD
hi MarkusH
i install CAD translator but when import .stp file to process simulation it give me that error.
error is in attachment.
thank you
What is the content of the created log file?
written like that.
TxSTEP2Cojt application
Translation Beginning on: 22 November 2018 15:05:43
The command line:
TxSTEP2Cojt D:\Thired semester\Robotics and Discret Processes\STATIE.stp -extIdMod 1 -dest D:\Thired semester\Robotics and Discret Processes -output STATIE.xml -accumulateMatrices -createAssySubfolder STATIE -emsClass PmCompoundPart;PmPartPrototype;PmPartInstance -l D:\Thired semester\Robotics and Discret Processes\TxConvert2co_STATIE20181122_150543.log -insertComponent
INFO [CONVERT2CO_2008] [2018_11_22_15:05:43] Loaded configuration file: C:\Program Files\Tecnomatix\CADTranslators\dat\steptojt.config
FATAL [CONVERT2CO_5009] [2018_11_22_15:05:44] Failed to run the translator.
written like that.
The command line:
Are you sure you have the correct license to be able to convert Step into JT?
The converter is included in CAD Translator, but it requires Teamcenter Visualization license.
See CAD Translator help file -> Licenses:
Best regards
Patrick
Hi together,
i need to import a CAD model of an UR Robot in Process Simulate. I have the model of the entire robot as STEP-file and all the single parts of the robot as .jt-files. I use "Process Simulate Standalone - eMServer compatible" Version 14.1.1
If i set up a new study and want to import the CAD file, I always get the message that the CADTranslator is missing on my machine.
Normally it should be installed i think. Is there another possibility to import the CAD files to simulate some simple pick & place operations with the robot?
Thank you an best regards
