How to make isoparametric curves in Robotexpert?
Hi Guys, I am trying to make a career path for polishing an irregular surface. The command  create isoparametric curves does not complete as when I place the solid on the item face says invalid object. I think it is because there is a surface and not a solid, but I do not know how to create the surface in robotexpert. Can someone help me.
Thank, Enrique
