How to synchronize a Rotary table with Robot
Hello ,
          I'm Newbee to the Process Simulate, i have seen in Some videos that a Rotary bed Is Connected to Robot for continuous weldig, but i dont know how to do it Process Simulate. im using Process Simulate 13.0 Standalone. If anyone  teach me how to do , it  will be  helpful for Me.Thanks in Advance
3 REPLIES 3
Re: How to synchronize a Rotary table with Robot
If you want to do this e.g. Kuka robot with two-axes positionier, you will need the correct machine data (MADA) to be able to do this correctly.
Best regards
Patrick
Hello Patrick,
Thank you very much For your Reply...Where can i Download the Kuka two Axis Positioners ?
Thanks in Advance
You can check if the needed model is available on KUKA Download Center.
If not, directly ask KUKA.
Best regards
Patrick
