Import autocad dxf layout file into PS
Hello all,
is there a way to import Autocad dxf files of layout which could be used to place and plan resources.
Re: Import autocad dxf layout file into PS
The dxf importer is included in the Standard Interface Package.
You need to:
  • install the "CADTranslators" from Tecnomatix DVD
  • make sure you can access the Standard Interface Package Named User [TN70075NU] license
If you have FactoryCAD installed - you can convert it to a 3D JT file for use in PS to position tooling
