Import of SOlid Works, STEP and IGES file into Process Simulate
what is the ways available to import Solid Works into Process Simulate. Is it possible to import Step or IGES into Process Simulate without translator?
Thanks in advance.
Rohit Mallya
Re: Import of SOlid Works, STEP and IGES file into Process Simulate
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
No translation without translator...
Check your license file. Probably Step and I get are already part of your license.
There is also a standalone translator: SolidWorks to JT, available from Siemens.
