Import weld points in Process simulate 13.1
      i am traying to import weldpoint in process simulate 13.1 but the option in
      Process-planning-Import mfgs from file is not hilighting.
      can any one tell me what is standard procedure to import weldpoint in process simulate 13.1.
Re: Import weld points in Process simulate 13.1
Hi Salim,
depends on which PS you use.
PS on eMS or PS Standalone eMS Based?
Best regards
Patrick
Thanks for your rplay,
    we are using PS Standalone eMS Based
Ok, therefore use an Excel sheet to build your list of Mfgs you want to import.
For more information use "PS Help -> Import Mfg"
The csv you need to import should look like this. (Important are the quotes for the coordinates, otherwise you will have problem with values like "100.13")
Best regards
Patrick
