Importing Fanuc robot program to Process Simulate
I'm using Technomatix Process Simulate 13.0. I am working with project where I need to offline program two Fanuc robots.
Models: Fanuc R-2000iB 165F and Fanuc M-6i with R-J3 controller. First I need to program R-2000iB.
First I'm trying to calibrate robot. I made program with R-2000iB where I use calibrating tool with three spikes and I programmed 10 points around each spike. I Exported this file succesfully to USB-flash and its .tp file (touch pendant?). I cant import this file to my robot in Process Simulate.
Problem: What do I need to do in order to get program from R-2000iB to robot in Process Simulate?
Thanks Smiley Happy
Re: Importing Fanuc robot program to Process Simulate
The .tp files are binary, you need to convert them to .ls ASCII programs with Fanuc tools.
Thanks for the help, now I converted the .tp file to .ls file. Do you know how to get .ls file to process simulate and try it with my robot? I don't find any option to import program than only "import robcad program"..
Juho
Program Inventory / Upload
Thank you very much!
Juho
Hi Juho,
How you converted from .tp file to .ls file. Have you used any converters.
Pl suggest.
Sandeep A
If you have Fanuc robo guide means you can import the .tp and export as .ls file.
