Is it better to work with Workstation instead of PC for Process Simulate?
If you can share your thoughts with me, that would help a lot!
Re: Is it better to work with Workstation instead of PC for Process Simulate?
hello,
process simulate works only on one cpu.
therefore is better to order a desktop workstation pc with big one cpu power (ex. Xeon 1620) and big grafic card.
for simply simulation in process simulate (olp) is a notebook ok.
Thanks!
How about Robcad? Is same valid for Robcad too?
robcad is the same.
ssd disk is to advise
Thanks!
