JT to STEP batch translation = Huge STEP file
Hi all,
I'm using the batch command for "jt_step.exe" when translating JT to STEP. I'm able to make the translation but I'm concerned about the size of the STEP file. For example, an 11 MB JT file results in a 400 MB STEP file.
Is there a way to effectively decrease the size of the STEP file on translation?
Re: JT to STEP batch translation = Huge STEP file
Hi, I'm afraid it is a problem of STEP. Generally, the JT files are very compact and small in comparison with other 3D CAD data formats.
Dave
