MaterialFlow on LineSimulation Mode
I have a cell with flow operations already created, linkeds, with non signals operations, that works in CEE mode.
But when I change to PLC INAT mode the operations are not triggered. I set the "loadpart" key signal and nothing happens.
At the sequence editor I see that the operation "startmaterialflow" is not ruunning.
Should I have do anything else to run this by a PLC?
Re: MaterialFlow on LineSimulation Mode
Hi Rafael,
this is normal behavior and was discussed in several threads already.
here, here and here.
Pls close this thread.
Guido
