Merging Process Simulate cells
Hello All,
Please let me know if in any way its possible to merge two process simulate standalone cells to be merged into one single cell.
Re: Merging Process Simulate cells
I think there is currently no way.
Merge is only available in PS EmServer Mode.
Kind regards,
Benjamin Voelzke
Thanks a lot for your reply.
Is there any other way other than "convert & insert CAD files" option to get contents of different workcell to existing workcell..?
If we use this option then the layout used in different study will be lost. (location where the equipments, parts are placed)
I'm not sure if it will help you, but you can try command "Import PSZX to Current Study".
D.
Thanks for your reply.
Have tried this option Dave. This imports only the parts, mfgs & engineering data.
None of the resources get imported nor their locations in layout.
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
I don't have much experience with pszx, but that shouldn't happen.
Cojt's exist in lib and have valid tunedata.xml?‎ No error message?
Am attaching the snapshot for "import to pszx to current study" option.
not getting any error message. But if I deselect all options in selection as in snapshot 2, then option to execute the command is disabled.
Feels to me that import pszx will work only for "parts, mfgs & engineering data".
Please let me know if any other method is available.
