Hello world!
I'am started to testing the automatic path planer module, but when I press the button, the next warning message appears:
I'am understand that i need to change the Motionparameter.e file, but i dont know how i can do it correct.
Can you help me in this question?
I'am using a 13.0.2 PS version and my robot is - kuka Kr300r2500 ultra. The aveliable motionparameter.e file attached.
Best regrads, Michail.
Re: Motionparameter.e
The "motionparamters.e" file is included in *.co or *.cojt of your robot.
This file you can edit with e.g. Notepad++.
Here just simply change or add one these two parameters to your "motionparameters.e" file.
For more information please take a look at the "Motionparameter.e documentation" in your Tecnomatix install folder:
e.g. C:\Program Files\Tecnomatix_13.0.2\eMPower\Help\Additional Reference Material\motionparameters-e.pdf
both parameters you will find in this docu.
Good luck
Best regards
