cancel
Mount tool Simulation layer command
Hi all,
I was wondering if there is a possibility to see what standard OLP command: Mount tool do in Simulation layer. I want to create OLP  command similar to one in Reference manual (see attached picture).
Thanks for answer
Re: Mount tool Simulation layer command
# Mount is simulated as attaching the tool to the robot TOOLFRAME.
Yes, but I want to know if it possible to see exact Simulation layer command. I want to create exact same OLP command as on one picture from Reference manual.
I guess, it should just be a # Mount command in the simulation layer
