New Feature, Signal Monitoring window
(view in My Videos)
Signal Monitoring is a tool that makes it easy to debug an entire expression or Logic Block module, and follow the signals as a simulation progresses. You can break an expression down to its smallest components for easy analysis and debugging. The Signal Monitoring window uses colors to make it easy to see the difference between the different boolean values (green for True, red for False) and numeric expressions (white). With the click of a button users can add or remove expressions from the signal watch.
Re: New Feature, Signal Monitoring window
This function is really great, but it is important to know that you have to double click the "connect to simulation" button to see the online status for a longer time. If you click it just once you can see only one cycle. Man Happy
But nevertheless this function is very useful in CEE simulations!
Smiley Happy
Liked it!!
Any more "New Feature" movies?
yes, there are some more videos downloadable from gtac. this videos are included in the "Tecnomatix_11.1_New_Features_Presentation.zip" file.
Thanks Patrick.
Are you with GSS?Smiley Embarassed
GSS???
Global Sales Services (Siemens)
ahh ok.
No I don´t work for Siemens. I work for ATEC GmbH as PS user.
