New Names for via Location in Process Simulate
is it possible to rename all  via Locations in a path,
in robcad is it "Rename path via locs".
With the intgrated "Rename Objects Tool " is it not possible,
there is only "add and cut " and "search and replace" possible.
I have more than 1000 vi locations.
Thank you and Best regards
Mr.Robcad
4 REPLIES 4
Betreff: New Names for via Location in Process Simulate
hi,
you can select the operation or locations and open the "rename tool"
you can find this tool unter Home menü.
Kind regards,
Benjamin Voelzke
Hello Benjamin,
i know this possibility, but with this is only
I need a new name, example from via123 to p100
                                                       via90  to p200 ...
This is possible with this feature.
Kind regards,
Benjamin Voelzke
Hello Benjamin,
it was to easy, Thank you very much.
Best Regards
