New cell : problem with kinematic of positionner
Hello ,
I am trying to create a new cell . I imported my postionner IRBP R300 from ABB .
After importing everything looks ok and now i have to define the kinematic but i click on the positionner in the tree and the command "set modeling scope" stay in grey .
Can you explain me why ?
thank you ,
Re: New cell : problem with kinematic of positionner
Hi
It could be due to that the positioner is a .co model. If so you need to convert it to .cojt
Andreas
Thank you , i figure out that i need to click on "create a monolithic JT file for the entire assembly" and no for each sub-assembly.
