Newbie Question
Hello all
   Developed kinematics for ABB IRB 1200. To verify the output I have tried joint jog and compared the joint vales with robot studio ( ABB simulation software ). PFA for the comparison. 1 & 2 seems fine, there is a slight difference in 3 but 4,5,6 is completely different. why it's behaving like this? am I missing something to configure?
  Thanks in advance...
Suganth
Re: Newbie Question
For a same TCP position, you can have up to 8 joint solutions. From your screenshot, it looks like you are not working with the same solution in both software.
If you move j4 and j6 by 180 degrees and move J5 to its opposite initial value, then you will get back to the initial TCP position.
