Object flow operation in Curve path
Hello All,
How to move an object in curve path in Object to flow operation?
And, How to create a curve path?
Thanks and Regards,
sriram123
4 REPLIES 4
Re: Object flow operation in Curve path
Siemens Legend Siemens Legend
Siemens Legend
You can use a curve geometry; create a new operation, assign new locations by pick along the curve. Align the location orientations from beginning to end. Create the new Object Flow operation, and check the "Use Existing Path" radiobutton. Select the path you created on the curve.
Otherwise, if you have the proper licenses, you could also use a Conceptual Angular Conveyor.
Hello Ray,
We are also try to create object flow operation in curve path.
As per your instruction the curve was created using curve geometry after that you are saying to create a new operation
Here we want to know which type of operation we should create?
Gautham
Siemens Legend
Hi Gautham.
I think one of the operation types is Object Flow. Please try that one.
Ray
Siemens Legend
O_F_O.JPGHere is the icon...
