PLCSIM safety
I tried to connect PLCSIM with safety program with PS, but I failed. Is somebody done it? Because everytime when I want to download SAFETY to PLCSIM, PLCSIM is going to STOP mode and PS stop with fault(PLC is not in RUN mode).
Is it possible provide SAFETY with PLCSIM?
Thank you very much?
Majlov
Re: PLCSIM safety
For the case no one answers (I can’t) :
I believe this you should rather ask the SIMATIC support/forums...
Siemens Industry Software GmbH & Co. KG; Anschrift: Franz-Geuer-Str. 10, 50823 Köln;
Kommanditgesellschaft: Sitz der Gesellschaft: Köln; Registergericht: Amtsgericht Köln, HRA 28227;
Geschäftsführung und persönlich haftender Gesellschafter: Siemens Industry Software Management GmbH;
Geschäftsführer: Urban August, Daniel Trebes; Sitz der Gesellschaft: Köln; Registergericht: Amtsgericht Köln, HRB 70858
Re: PLCSIM safety
hello and good morning from Munich,
today, Siemens PLCSIM does not support safety plc.
Kind regards,
Benjamin Voelzke
Re: PLCSIM safety
thank you very much for yours quick responses.
In PLCSIM is possible simulate safety. I tried it(see attachment).
Thank you.
Re: PLCSIM safety
i think in the picture is dosen't load hardware.
Kind regards,
Benjamin Voelzke
Re: PLCSIM safety
I made that PrtSc and I loaded hw..
Re: PLCSIM safety
ok you are right.
my problem was, i write from process simulate safety signals in PLCSIM and PLCSIM stops.
PLCSIM Safety check the changes on input value.
Safety input is changed from outside. this is not allow.
Safety signal can only change the value via hardware inputs.
Kind regards,
Benjamin Voelzke
Re: PLCSIM safety
Aha..
Ok, thank you very much for your help.
