PS 11.1 Controller settings and Frames not saved after save to eMServer
Hi everyone,
I have error message every time I save to eMServer. Controller settings and Tool and Base settings are not saved and every time I start PS, I have to set it all up again. It is very time-consumig.
Anybody know how could it be solved ?
Re: PS 11.1 Controller settings and Frames not saved after save to eMServer
You probably forgot to import RoboticsCust customization in your eMServer schema. It is under eMPower\InitData\RoboticsCust.
I tried to follow your advice and import RoboticsCust customization, but got another error message.
The message is self explanatory, you need to go to Admin Console and close all eMS session before you can import a customization.
I did it too and still got the same error message.
And disable login as well? You should have no more sessions alive in Admin Console.
I do not have more clues.
disable login as well and did not help.
Thank you anyway.
To import the customization, you cannot have any Project loaded.  When starting PS, at the Open Project dialog, hit Cancel; or if in PS and a Project is open, Close the project.  Then try to import customization again.  The user must be administrator, or a user in administrator group with proper permissions for the schema.
