[PS] How to turn an axis of the positioner in between the operations?
I'm trying to make turns in between the operations. For example, how do I turn an external axis by 60 degrees after each operation? I could use poses but since the number of turns is high there should be a smarter way.
Re: [PS] How to turn an axis of the positioner in between the operations?
In which mode (Time Based - Standard Mode or Event Based - CEE) do you want to move your positioner?
In Time Based you need a device operation for each rotation you want to make.
In Event Based you can control the positioner by signals anytime you want.
Best regards
Patrick
Hi Patrick,
Thanks for the tip. I will look into signals.
