PS JT Version 10.0
hello,
i have a question about the JT Version 10.
I have converted Catia Files to JT Version 10.
My Problem:
On my machine is install process simulate version 11.1
in this version is only jt version 9.1 supported.
how can i work with the new jt version under ps11.1?
is this only supported for ps11.1 tr3?
can i downgrade the jt version 10 files? (without NX)
Kind regards,
Benjamin Voelzke
Re: PS JT Version 10.0
Hi Benjamin,
I don't know if you have solved the issue, but still.
In Teamcenter Vis you can export to an older version of JT - i don't know if that could help you.
Andreas
thanks.
i solve the problem self.
i convert the JT file  with JT Utiluties to a older version.
What is the difference between JT 9.5 and JT 10?
Kind regards,
Benjamin Voelzke
