cancel
PS Multiscreen windows positioning problem
Anyone of you have experience with multiscreen problem? When I work with two or more monitors and then I move to a single monitor, all the tabs and windows are still opened in the old position, out of my screen, impossible to reach.
Do anyone of you have some solutions to fix this issue?
thanks
Roberto
Betreff: PS Multiscreen windows positioning problem
I solved this by creating zwo layouts - one standard layout für multiscreen, one for singlescreen.
In the Tecnomatix Doctor under the Tools menu you can find an option to Reset Dialog Position.
This will restore the OOTB dialogs position and resolve the problem.
Best Regards,
Yuval
